Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1988 Buick Regal Power Loss
Auto Repair1975 Chevy Nova Car Won'...
Auto Repair1995 Toyota Camry Door H...
Auto Repair1996 Other Saturn Models ...
Auto Repair1994 Other Saturn Models ...
Auto Repair1999 Nissan Sentra No Start
Auto Repair2000 Chevy Impala Engine...
Auto Repair2001 Saab 9-3 Repair Ques...
Auto Repair2003 Chevy Avalanche Fue...
Auto Repair1993 Toyota Corolla Lamb...
Auto Repair2002 Dodge Caravan 2002 ...
Auto Repair1999 Lexus Rx 300 Brakes...
Auto Repair1999 Ford Expedition
Auto Repair1996 Ford Explorer
Auto Repair1992 Lincoln Continental ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 BMW 528 Rough start when cold only
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Wed Jan 23, 2008 5:15 pm
By Geoffflowers@hotmail.com, New to the forum
Give Feedback | Votes: 0
Engine problem
1998 BMW 528 6 cyl Two Wheel Drive Automatic 200000 miles
Need help...Car sputters and vibrates when first start then choke seems to kick in and runs fine. If attempt to start again runs fine but if I leave car off for say 8 hours will have rough start again. Disconnected MAF sensor,O2 sensor, even CTS sensor looking for a different response. perhaps its the fuel filter which hasn't been changed for more than 40K. What do you think.
Signed
Too proud to have OBD scanned
Find a repair manual for your BMW 528 Repair Question.
By Advertisment,
Posted at Fri Jan 25, 2008 7:26 am
By Dr. Hagerty, Moderator
Reputation: 134.3Reputation: 134.3Reputation: 134.3Reputation: 134.3Reputation: 134.3Reputation: 134.3Reputation: 134.3 (134) Give Feedback | Votes: 7
An OBDII car is best diagnosed with the correct scan tool. If there is some issue with any of the emissions control equipment you might want to correct it and perhaps then the problem can be resolved.
Posted at Sat Feb 16, 2008 12:03 pm
By pit456, New to the forum
(13) Give Feedback | Votes: 0
Hi, I had the same problem with my 528i. It took me weeks to figure out what it was. What you are describing sounds very similar to my problem. Mines turned out to be a faulty Coolant Temperature Sensor. What happens is when the engine is cold the faulty temperature sensor cannot tell the engine it needs a little more fuel to start. This causes the idle to shutter and hesitate. Engines need more fuel when they are cold and a little less when they are warm/hot. This could explain why it only happens when it is cold. I am not saying this is your problem, but it could not hurt to check it out. I took mine to the mechanic and they wanted to charge me $240 to fix the problem. Luckily I figured out it was a $19 Coolant Temperature Sensor that only took about 5 min to replace. The part number I believe is 13621703993. One word of caution is when replacing the switch do not screw it in too tight. The tip is made from hallow copper and if you tighten it too much you will break it right off. Best suggestion, snug, but not too snug. Go to realoem.com type in the part # and get a image of where the temp sensor is located. Good Luck
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
