Suspension problem
1998 BMW 328 6 cyl Front Wheel Drive Manual 223000 miles
I took my 98 328i to have the front end checked out because of some noise it was making over bumps. My mechanic told me that my front end needed sway bar links as well as front to end bushings. Is the problem as simple as that? No struts needed?
At 223k I would think the suspension would be worn to the point of replacement, however the fact is that I am not there and if the tech that is helping you decides the work should be performed, then you have a decision to make.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
