Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair2000 Chevy Silverado Not...
Auto Repair1988 Ford Bronco Will No...
Auto Repair2001 Toyota Sienna Stuck...
Auto Repair94 Pontiac Grand Am 2.3 Q...
Auto Repair2004 Ford Expedition Con...
Auto Repair1997 Other Plymouth Model...
Auto Repair2001 Ford Windstar Shutt...
Auto Repair2003 Mitsubishi Montero
Auto Repair1999 Lincoln Continental ...
Auto Repair1996 Chrysler Town And Co...
Auto Repair1995 Chevy Tahoe O2 Sens...
Auto Repair1986 Other Isuzu Models I...
Auto Repair1999 Volkswagen Jetta Ra...
Auto Repair1998 Dodge Neon Overheating
Auto Repair1991 Other Mercedes Benz ...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 BMW 328 Check Engine Light
Posted at Tue Mar 04, 2008 7:50 pm
By Ryan82586, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1998 BMW 328 6 cyl Two Wheel Drive Manual 160k miles
My check engine light has recently come on. I tried erasing the stored code by pulling the positive on my battery for a few seconds. Check engine light remained on directly at start up. I was wondering if there is a way to get the codes from the Data Link Connector without having a Peake or OBD or other diagnostic tool. I have a suspision that this is possible, because unknown by many, I know a way of simply reseting the oil service and inspection service lights without having a tool at all. Just some common things I could find around the house.
There must be a way. I'm thinking that if you ground a certain terminal (or several) in the data link connector and then turn the ignition to position 2 that the check engine light will blink a series of codes with pauses, short blinks, and long blinks or something to that affect. What are your thoughts?
Thanks!
Find a repair manual for your BMW 328 Repair Question.
Posted at Tue Mar 11, 2008 6:09 pm
By Dr. Hagerty, Moderator
Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7 (103) Give Feedback | Votes: 6
The faults can be retrieved with a relatively inexpensive generic scanning device. Unfortunately this is your only option as this version of Motronic does not support using that particular self diagnostic as do earlier versions.
Posted at Thu Mar 13, 2008 8:07 pm
I scanned the car with my OBDII tool and came up with codes P1423 and P1421. I looked up these codes, its reads "Secondary Air System bank 1" and "Secondary Air System bank 2".
I know what the Secondary Air Pump is, but where exactly is bank 1 and bank 2? Does this whole system need to be replaced or certain components repairs/replaced? How neccessary is it? Thanks
Posted at Thu Mar 13, 2008 8:19 pm
The problem that you are up against is possibly due to the fact that the vacuum hose to the secondary air injection valve has a crack in it. Open the hood and look at the front right corner of the engine and find the valve that is connected to the air pump that is located in front of the shock tower, there is a small hose connected to the round silver colored device that is the secondary air injection valve. I inspect this hose and repair or replace the vacuum line going to the valve. Reset the faults and repost if this does not help fix this issue.
Posted at Fri Mar 14, 2008 7:09 am
You are talking about the black plastic hose that is about the diameter of a quarter, leading from the secondary air pump to the secondary injection valve, right? This valve is also known as the switch valve, correct? What about the small metal hose thats coming from the secondary injection valve; should I be checking this too?
Posted at Sat Mar 15, 2008 8:44 am
I inspected both the large hose and the very small hose. Both of which dont appear to have any cracks, holes, or failures at all. However, the small hose does appear to be a little worn out, most likely from the excessive heat under the hood. Should this be replaced anyways?
It must be more then just the hoses. I dont think that both bank 1 and bank 2 would fault if just one of the hoses had a leak. It's starting to sound more like the Air Pump is simply failing.
Any ideas, on what to do next?
Posted at Mon Mar 17, 2008 5:13 pm
Yes, that is a possibility that the fan is failing, I had one do that to me, and the fan checked out, it was an intermittent failure, try replacing the fan and let us know.
Posted at Mon Mar 17, 2008 7:58 pm
By fan, do you me air pump? the one that is inches away from the passenger side view mirror?
Posted at Tue Mar 18, 2008 5:14 pm
Pump, yes.
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
