Car Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 BMW 328 White smoke
Posted at Fri Jul 03, 2009 7:36 pm |
By
nwallis,
New to the forum |
Give Feedback | Votes: 0 |
Transmission problem
1998 BMW 328 6 cyl Two Wheel Drive Automatic 178000 miles
I have a 1998 BMW 328i with an auto transmission. i recently purchased this car at an auction and vehicle was previously abandoned. i just had a key made and started it up for the first time and it ran rough and was blowing white smoke. i ran head gasket tests and the car passed them all. so then i thought bad gas and replaced gas in the tank with fresh and now engine runs smooth however still blowing white smoke and now the transmission does not always want to engage into gear and sometimes disengages while driving. white smoke smells like burning trans fluid so i am thinking the vacuum line on trans is pulling fluid into engine causing smoke and loss of fluid is causing shift problems. anyone with bmw experience or that has had a similar issue with any ideas or suggestions would be great. thank you |
Find a
car repair manual for your BMW 328 Repair Question.
Posted at Sat Jul 04, 2009 9:16 pm |
By
Dr. Hagerty,
Certified 2CarPros Master Technician |
(83) Give Feedback | Votes: 20 |
There is no place for the transmission to get fluid in the intake on that car, white smoke usually is coolant. |
Find a
Posted at Sun Jul 05, 2009 10:28 am |
By
nwallis,
New to the forum |
ok i was not sure. im a lexus tech and on toyota trans they have vacuum modulators that can go bad to allow atf to enter engine and burn. In this case i was thinking that because i am loosing my trans fluid somewhere and its not leaking out. I understand white usually means coolant but in my case it is not. the coolant level is not the slightest bit low, the car is not over heating and the white smoke DOES NOT smell anything like burning antifreeze (i have seen, smelled, and fixed many toyota head gaskets). also found no water in oil or oil in coolant. i can do a compression test if you know off the top of your head what the pressure readingings should be, how ever i know compression is fine because engine runs smooth and does not miss. so what else can cause white smoke? I do know it had bad gas, car sat for a 8 monthes to a year. when i drained old gas it was very brownish. when new gas was put in the car ran much much better, still smoking. any ideas other than head gasket? think outside the box. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
