My 2000 323i just started doing the exact same thing a couple of days ago. I've done some searching and it seems that the temp sensor and relay are built into the variable speed electronics integrated into the fan. If one of these fails, it runs wide open like that. It also seems that this is a common problem with these fans and you have to replace the entire unit. I've been unplugging mine when I'm stopped for a prolonged period of time. I'm considering replacing it myself, but I haven't found a definitive answer regarding the part number to order or exact instructions regarding the swap. All I know is that most report a $400+ bill to have it repaired and I think the fan is a little over half. Anyone done this installation themselves? It looks like there is plenty of room to get it out and in without removing much, I'm just not sure of all the screw locations or the "gotchas" that you don't find out about until you dig in. Hopefully someone can save us the trouble of finding out the hard way?
