Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Gmc Jimmy P0141
Auto Repair2004 Chevy Trailblazer ...
Auto Repair1993 Toyota Camry Volta...
Auto Repair2002 Chevy Silverado Fa...
Auto Repair2002 Ford F150 Told Mas...
Auto Repair1997 Chevy Cavalier Blo...
Auto Repair2002 Ford Taurus Squeak...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Audi A8
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Aug 28, 2008 9:34 am
By 1romik, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1998 Audi A8 V8 Four Wheel Drive Automatic
Hello, I have 1998 Audi A8, and one day I parked my car and turned off the engine, and the next day went to go start it, but it would not start. I also have another one and took the computer from the other one, and put it in to my working A8, and it worked, so the computer in it is fine. I checked the fuel injectors harness, and there is no power in it. What could have possibly happend?
Find a car repair manual for your Audi A8 Repair Question.
Posted at Thu Aug 28, 2008 5:11 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 102.9Reputation: 102.9Reputation: 102.9Reputation: 102.9Reputation: 102.9 (103) Give Feedback | Votes: 27
theres a few possibilitys, first thing to do is check for key on power. with the key on the power terminal should have +12v constant, you can check that with a test light.
next step if that is there is to check for a pulsing ground signal which completes the circuit and fires the injector, if you have a noid light hook it up and crank, the light should flash. if not its lacking one of the above.
are you getting spark and good fuel pressure to the rail?
Posted at Fri Aug 29, 2008 8:30 am
Hello, I hooked up the noid light, and nothing was flashing. But I have have fuel pressure and good spark.
Posted at Fri Aug 29, 2008 10:34 am
unhook all the injectors and check again for a pulse when cranking.
do you get a real fast blip when turning the key to on?
are you getting +12v to the injectors with key on? or none.
can you mark down all the injector colors and what cylinders and post them here?
you want to check for pulse on all cylinders also.
Posted at Fri Aug 29, 2008 3:32 pm
Hello again, I tried everything you told me to do, but none of the injectors have any pulse. I want to know where the pulse is supposed to come from (ignition coil, a relay etc.), basically what causes the pulse to happen.
Posted at Fri Aug 29, 2008 6:28 pm
you get the pulse from the computer first of all but what it gets the information from for pulse is the camshaft position sensor.
its located on the rear of the left cylinder head. unhook it and try to start the vehicle, you may have to crank it for 10-15 seconds, and it should fire up if the camshaft sensor is at fault, but it still could be bad and the vehicle not start with it unplugged.
Posted at Fri Aug 29, 2008 6:33 pm
also i forgot to mention can you have it scanned for codes to see if thers any issues before we get too advanced?
Posted at Mon Sep 01, 2008 2:22 pm
I scanned the car for some codes, and I got a code of P1856.
Posted at Mon Sep 01, 2008 3:22 pm
P1856
Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr.
i would like you to check the TPS voltages closed and wide open throttle. post them back here.
also disconnect the tps then try to recheck for a pulse. anything?
try disconnecting cam sensor and seeing.
if that doesnt do it chances are thers a damage in a harness somewhere, try wiggling the connectors around and see if anything. if not its time for a pin to pin test and a pin to ground test.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
