Auto Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1998 Audi A4 low oil pressure
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Sat Jun 14, 2008 10:19 am |
By
bryan1,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1998 Audi A4 4 cyl All Wheel Drive Automatic
Recently I had the motor rebuilt, everything is new including the oil pump but not the crankshaft (it was polished). Since putting the rebuilt motor in I have been experiencing very low oil pressure readings when warm. (at cold idle i get 60-70 psi and at warm idle i get 6-8 psi) At this point I have changed the bearings to check them for wear and also for the possibility that they may have been the wrong bearings (main caps only). This did not correct the issue. There are no external leaks. I have changed the oil filter, experimented with various oil viscosities, but have not found a correction. Would it be possible that the oil pump may be the issue, I primed it when I installed it but didn't get to start it until a week later, could it have lost its prime? And could the relief valve and pump drive gears in the oil pump be the issue? Thanks
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your Audi A4 Repair Question. |
Posted at Sat Jun 14, 2008 3:51 pm |
By
bryan1,
New to the forum |
Thanks for your quick response. The motor was rebuilt due to high milage but also because when I had purchased it, the vehicle was hard to start. The intake cam had to be replaced(badly damaged). It also looked like the old owner had a timing belt break and then unloaded it. It was knocking when I finally pulled the motor. I replaced the cam bearings and completely rebuilt the head as weel as the motor. Cam clearance could be an issue. The thing that is confusing me is the idea that the oil pressure is good when it is cold but when you reach operating temperature it becomes low. Would bearing clearance be effected by temperature? Like I first thought, maybe an issue with the relief valve? The main bearings have been done twice, once with the new motor and once again yesterday, I did this incase the oil pump may have caused damage. The other thing is that when I first started the car after the engine replacement it seemed to take an abnormally long time for the lifters to pump up. I am going to guess at maybe 4-5 minutes. This is why I thought that it may have been the bearings. Please let me know if you need any more information, I am DEEPLY in debt with this car and it's problems, but I cannot sell it like it is, besides I did like the car before these issues. Thanks again for your response and help.
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
