Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair1988 Ford Bronco Will No...
Auto Repair2001 Toyota Sienna Stuck...
Auto Repair94 Pontiac Grand Am 2.3 Q...
Auto Repair2004 Ford Expedition Con...
Auto Repair1997 Other Plymouth Model...
Auto Repair2001 Ford Windstar Shutt...
Auto Repair2003 Mitsubishi Montero
Auto Repair1999 Lincoln Continental ...
Auto Repair1996 Chrysler Town And Co...
Auto Repair1995 Chevy Tahoe O2 Sens...
Auto Repair1986 Other Isuzu Models I...
Auto Repair1999 Volkswagen Jetta Ra...
Auto Repair1998 Dodge Neon Overheating
Auto Repair1991 Other Mercedes Benz ...
Auto Repair1996 Volkswagen Jetta Ai...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Audi A4 Gas Odor
Posted at Mon Apr 28, 2008 6:38 am
By LittleNeckA4, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1998 Audi A4 6 cyl All Wheel Drive Automatic 83000 miles
Hi Pros, I have a 98 Audi A4 2.8 with a little over 82,000 on it. When the car is running and I have the sunroof open especially, there is a strong odor of raw gasoline that enters the cabin. Also the car is not getting good gas mileage, maybe about 14 mpg. I have changed the Gas Cap, Fuel Pressure Regulator and EVAP Canister Purge Valve. This week I will be changing the Fuel Filter as well. I don't know what else to do or look for. Appreciate any help I can get at this point.
Find a repair manual for your Audi A4 Repair Question.
Posted at Tue Apr 29, 2008 4:28 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579Reputation: 579 (579) Give Feedback | Votes: 75
Look around the injectors and at any fittings under the hood.IF you smell fuel, there is probably a leak and it needs to be found. Any check engine light? wondering if it is just running too rich instead of leaking. When was the last tune up? does it feel like it is missing at all?
Posted at Wed Apr 30, 2008 8:39 am
Dealer said injectors are fine, car does have a bit of a rough idle. The CEL is on but the dealer said it was due to a bad Coolant Temperature Sensor that I see no sign of being bad. I will be doing a tune up this weekend inlcuding all filters plugs & wires. What tests can be ran to determine if the car is running too rich?
Posted at Wed Apr 30, 2008 9:26 am
Normally the PCM will store a code that says too rich, but if the coolant sensor is bad, that will also cause the problem
Posted at Thu May 01, 2008 8:11 am
A bad coolant sensor will cause what problem, the gas odor, the car running too rich or just the CEL. The CEL is not my main concern, the gas odor is.
Posted at Sat May 03, 2008 2:14 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8Reputation: 673.8 (674) Give Feedback | Votes: 63
If you don't have an actual fuel leak and the engine is running rich the CTS could be the cause if it doesn't switch from open loop mode meaning the computer will constantly be giving the engine fuel when not needed.
I strongly recommend have your fuel pressure checked. Could be a bad fuel pressure regulator or a clogged fuel return line overpressurizing it-excessive fuel pressure.
Running rich should throw out a code P0172 and/or P0175. Typical symptoms of an engine that is running rich (too much fuel, not enough air) are poor fuel economy, elevated emissions (Carbon monoxide or CO), and engine may have rough idle or surge condition.
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
