Electrical problem
1998 Acura TL 6 cyl Front Wheel Drive Automatic 118614 miles
I own a 98 3.2 TL with 118614 miles on it. On a recent trip, the speedometer started to jump, die, then work again. It shut off the cruise control every time it moved. Since I got home the speedometer hasn't worked at all. Also, since I got home the D4 indicator light now flashes after the car goes for 30 seconds, no matter what gear I have it in. The flashing is a regular pace on, off, on, off, not like a short. Could the speed sensor cause the speedometer to go out like this? If not, then I guess I'll replace the cluster. And what does it mean when the D4 light flashes? Thanks for any help you might give.
