Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Chevy Tahoe Abs Lig...
Auto Repair2000 Other Volkswagen Mod...
Auto Repair1997 Chevy Monte Carlo L...
Auto Repair2004 Other Gmc Models Eng...
Auto Repair1999 Other Nissan Models ...
Auto Repair1988 Chevy S-10 Vent Con...
Auto Repair1991 Chevy S-10 Won't Start
Auto Repair2000 Chevy Cavalier Grin...
Auto Repair1993 Gmc C1500 Coil
Auto Repair1997 Chevy Silverado No ...
Auto Repair1995 Geo Prizm Rubbing N...
Auto Repair1999 Toyota Sienna Car W...
Auto Repair2002 Ford Explorer Left ...
Auto Repair2005 Chevy Malibu Headli...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Acura Integra transmission problem, maybe cooling syst
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Apr 10, 2008 1:02 pm
By 98ainc, New to the forum
Give Feedback | Votes: 0
Transmission problem
1998 Acura Integra 4 cyl Front Wheel Drive Automatic 228300 miles
My 98 Acura Integra GSR had about no acceleration last week. I checked under the hood and saw the (automatic) transmission fluid dipstick was loose. I put it back in place after checking and found that the fluid was about gone, added more fluid (dexron6 from auto supply store) plus Rislone transmission additive and this fixed the acceleration problem. I noticed the coolant reservior was empty and filled it too. I've since noticed the coolant is definitely leaking from a corroded hose connection which looks like it can be fixed w/a new hose.
The real problem is that I've noticed a decline in acceleration and when I put posterboard under the car (gravel driveway, wanted to catch & see what's leaking) I saw what looks like red-brown transmission fluid. With the automatic transmission, I don't know how to check for any leaks because I can barely get to the dipstick and not sure of what to check on the transmission itself.
Please help.
Find a repair manual for your Acura Integra Repair Question.
By Advertisment,
Posted at Thu Apr 10, 2008 4:58 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9 (132) Give Feedback | Votes: 24
are you sure you did not overfill the transmission when you filled it?
best bet would be take it in and have them examine the transmission on a lift that way you can see where its leaking from. may be a bad pan gasket, or a loose drainage bolt, or it was overfilled and it overflowed out.
Posted at Thu Apr 10, 2008 5:55 pm
I added 5qt of atf fluid, plus the additive. From reading the repair manual I know know the capacity is just under 6qt for the atf. It's very possible I overfilled. When I checked the atf dipstick after cleaning it, there was still fluid on it.
After reading part of the manual and seeing the picture that shows the atf cooling hoses, I wonder if the atf is leaking into the cooling system or vice versa.
Posted at Thu May 15, 2008 12:50 pm
By eksine, New to the forum
I'm going to have to back up blackop555's suspicion that the atf was overfilled. on my accord the atf is about 6 quarts total taking into account that the torque converter holds 3-3.5 quarts so that a drain and fill is roughly 2.7-2.8 quarts. At the risk of making you seem foolish, but check your manual again that the capacity you stated is for the entire system and that a drain and fill is actually not 5-6 quarts. that really sunds too high although this is my best guess not knowing the fluid capacity in your specific car. use your atf dipstick to double check, the fluid should be between the two markings. check both sides of the dipstick to get a better reading
Posted at Fri May 16, 2008 4:14 am
as eksine says, half of the trans fluid is in the torque convertor so if you put in 6 more quarts including the additive and there was 3 leftover, you have 9 quarts in it.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
