Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Chevy Lumina
Auto Repair1997 Chevy Cavalier Blo...
Auto Repair1998 Chevy Lumina Rear ...
Auto Repair2002 Honda Accord Emerg...
Auto Repair1995 Mitsubishi Galant ...
Auto Repair1997 Mitsubishi Galant ...
Auto Repair2004 Ford Taurus Auxlia...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Acura Integra knock sensor
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Sep 24, 2008 12:22 pm
By shin_2max, Likes cars!
Give Feedback | Votes: 0
Engine Mechanical problem
1998 Acura Integra 4 cyl Front Wheel Drive Manual 198000 miles
I have rebuild my motor (1.8L v-tec) b18c1 last year due to a head gasket problem and water in block. My cousin and I put the the motor back together again and put the motor back into the car. All sensor had bee replaced with a motor at that time when we dropped it back to the car. Unfortunately, a check engine light came on when we took it for a test run. it was throwing a code 23 which was a knock sensor curcuit fault. At that time i was toatally out of cash so i waited a month to fic the problem. Bought a new from pepboys put that one to use but while installing the knock sensor i dropped it. Assuming that it was ok i finish installing and tested that one it was sure that the engine light came back on throwing the same code. So I went back and returned that one as a defected knock sensor and got a new one, hooked it up make sure the wire was plug in tight and make sure the wire was not cut ot split anywhere. I drove it, about some 2 min. and the check engine light came back on again. I am completely drained and fustrated because i need it to work and kill the engine to pass emmision to get my tag. please help A.S.A.P. thanks
Find a car repair manual for your Acura Integra Repair Question.
Posted at Thu Sep 25, 2008 4:22 pm
By KHLow2008, Moderator
Reputation: 169.5Reputation: 169.5Reputation: 169.5Reputation: 169.5Reputation: 169.5Reputation: 169.5Reputation: 169.5Reputation: 169.5 (170) Give Feedback | Votes: 13
Hi shin_2max,
Did you reconfirm the error code is from the knock sensor?
1. Check the ignition timing. Too advanced timing would cause the knock sensor to maifluntion.
2. Check the timing belt synchronisation, out of sync would cause this too.
3. Check the fuel quality.
Posted at Mon Sep 29, 2008 10:10 am
Well, thanks for responding back my consern. I have confirmed that it was a cel code 23 a knock sensor malfunction circuit fault. When the engine is cold the timing belt is will off the mark but when the engine warms up the indicator is position on the mark and it very well clear that the timing belt is right. I don't know about the ignition timing though, I'll check that....I only pump 91 octane gas from chevron only and possible from 76. I don't know what else....I talked to one of my friend who has a friend that use to work for Honda tec, he said that the other reason is that it might be my motor that causing the problem...i don't know??? Need more information please.???? thanks.
Posted at Tue Sep 30, 2008 3:22 am
Using the timing light to confirm the timing belt is not the correct procedure as you have 2 camshafts and the one running the distributor might be correct whereas the other might be out of sync.
What you have done is checking the ignition timing, not the crank and cam synchronisation.
Connect the SCS and recheck the timing, adjust if necessary.
Too high compression ratio can cause the problem too. Did you reface the cylinder head and block?
Posted at Wed Oct 01, 2008 3:52 pm
I had checked the timing and it was good. Thanks for telling me that about the cams and the crank I'll check on that. When i check the scs service sonnector all it give me is the cel code 23 (blinks two times slow and three times fast). But I'll check the compression to see if the compression is too high. Yes, when i rebuilt the motor top and bottom i had them resurface both blocks just to clean it. If there is any thing else please let me know I'm trying to do this as fast a possible and as precisely too. to get it to pass emission for my tag. thanks, I'll check on that and post my concern when i get to it.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
