Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Isuzu Rodeo Questio...
Auto Repair2007 Jeep Wrangler Stee...
Auto Repair2000 Pontiac Grand Am
Auto Repair1988 Toyota Supra Engin...
Auto Repair1993 Cadillac El Dorado ...
Auto Repair1992 Toyota Tercel 1992...
Auto Repair1997 Ford F150 Rotor Be...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Toyota Pickup Slow to Heat up
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Sep 04, 2008 9:27 am
By howielam, Likes cars!
Give Feedback | Votes: 0
Heater problem
1997 Toyota Pickup 4 cyl Two Wheel Drive Automatic 68000 miles
My '97 Tocoma 2.4L started to heat up very slowly last winter. It takes much longer than normal for the temp gauge to reach the halfway point. Even afterward, I am getting little heat inside the cabin. Here are the things I have done yet the problem still exists:
1) Replaced thermostat (twice in a week).
2) Put cardboard in front of radiator to block cold air.
3) Replaced radiator cap.
4) Verified the heater core valve at the firewall to operate properly.
I read from some Forums that people with similar problem was able to correct it by replacing the water pump. It does not make sense to me ! If the water pump is a culprit, the engine would have overheated instead of slow to warm up.
Winter is right around the corner. Please help !
Find a car repair manual for your Toyota Pickup Repair Question.
Posted at Sun Sep 07, 2008 12:48 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3 (990) Give Feedback | Votes: 75
Could be the heater core clogged-up Try this find the feed side of the heater hose disconnect the other side start truck up coolant should come out
Posted at Sun Sep 07, 2008 7:25 pm
Thanks Rasmataz for replying. But how does a clogged heater core explain the temperature gauge taking a long time to reach the halfway point (normal operating temp). It used to take only 5 minutes and I am roasted. Now it takes like 15 minutes and I am still shrivering.
Posted at Mon Sep 08, 2008 1:40 am
You did the thermostat 2x the purpose of it is to control engine temperature. For some reason you're heating up in 5 mins. now your not getting it if there's no coolant flow thru the heater core you ain't gonna get it. Pull both of the hoses from the heater core and see if coolant is coming out of the hose. If so it might be clogged up.
Water pump not working it will overheat within 5 mins. BTDT-start the vehicle up and let it warm-up and feel for cold spot across the radiator if so the Rad is clogged blocking the flow of coolant.
BTW is the thermostat installed correctly with the jiggle valve in proper place.
Posted at Fri Sep 12, 2008 9:53 am
Hi rasmataz,
checked the heater core and confirmed it is NOT clogged.
I noticed one thing that is strange: the radiator fan runs even in the morning when I fisrt started the car (AC off). The car has sat all night and the engine is cold ! Is this normal ??? on this model ('97 Tacoma 2.4L 4-cyl 2WD), does the fan run full time ? variable speed ? if variable speed, where is the sensor to control the speed ?
Help help help !
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
