Hi lyricsdaddy1,
Check by the following order.
When the brakes are sticking, jack up vehicle and put on stands. Release bleeder nut, if wheels becomes loose, it is probably the hose. Take care not to burn yourself as it is hot.
If not the above, wait for brakes to cool and remove lower caliper bolts. Flip caliper up to get brake pads out. If it is difficult, the slider bolts should be stuck, most probably the pads will wear slanted.
Remove brake pads and reinstall slider bolts. Push caliper in and out on the slider, if movements are smooth, it is not the problem.
Check caliper piston dust cover, if torn or displaced, you might have rust jammimg up the piston.
Use G-clamp to push piston back, should be easy. If not you have to service the caliper assy, replace piston if rust has caused it to have craters on the surface.
If piston is stuck, get someone to pump the brake pedal a slowly few times to get the piston out, otherwise you would have difficulty taking it out later.
