Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1997 Toyota Corolla 4 cyl Two Wheel Drive Automatic 130000 miles
We had our 97 Corolla checked by a local mechanic and were told it needed the EGR valve replaced. They quoted $389 to replace the EGR valve for us and I have been told that seems like a bit much for a simple replacement. Is it difficult to replace the EGR valve? Can it be done by a do-it-yourselfer? Is $389 too much for this simple replacement?
Honestly, it does not sound excessive. The part can run between $150-200, plus a gasket.
The bolts that hold it down can be rusted and hard to get out, since they are exposed to high temps.
If you want to do it yourself, look at the Car Repair Manual link in the post, or buy a Haynes manual.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
