Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1997 Toyota Camry 4 cyl Two Wheel Drive Automatic
I have a camry le that is not charging. The wiring, battery,belt, and connections are all good. The alternator is suspect but bench tested OK at O'reily auto parts. Any ideas?
Install the alternator back into the car. Drive the car back to Checker O'Reilly and have them test the entire electrical system (all battery, starter, and alternator). Alternator may have bench-tested good, but its wiring back to the battery may be faulty (somewhere that you could not see). Testing in vehicle will give you and the attendant opportunity to see the entire problem.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
