Engine Mechanical problem
1997 Subaru Legacy 4 cyl All Wheel Drive Manual 125000 miles
I recently changed the air filter on my 97 Legacy and the check engine light came on shortly after. The code said that its the MAF sensor or BArometric Pressure Sensor. The MAF Sensor is right there so maybe something sucked into it. Its at least a $200 part so I would like to test it before I replace it. Is there and easy way or somewhere to rent a tester? I just replaced this sensor about 2 years ago. Could it be bad again already?
