Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Heater problem
1997 Subaru Legacy 4 cyl All Wheel Drive Automatic 190,00 miles
The defroster and heater does not work. Are there any fuses that would control this, or is this a problem with the thermostat? The temperature guage in the car is always in the normal range.
Ok what do you mean that the heater don't work. Does the blower moter not come on at all? Does the motor come on and there is not heat? Get back to me with this and we will go from there ok.
Thanks for getting back to me. My husband figured out the problem. A little door behind the glove box had a small cable attached to it. The cable had come off, so the door would not open. All is well now and plenty of heat .
Thanks anyway. I will use you again if need be..
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
