Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Subaru Impreza 2.2
Posted at Tue Nov 20, 2007 3:43 am
By egnorm, New to the forum
Give Feedback | Votes: 0
What are the consequenses if you rotate the crank and cams after removing there timing belt? I must be the only one who has had trouble after a belt change (actually did it to replace crank and cam seals). The belt is aligned properly- I've reset it at least six times. I did move one camshaft when it was disassembled- later I read not to do this- could cause hla bleed down. Would this cause any issues that would make the car not start? Turns over but wont start.
Find a repair manual for your Audi A8 Repair Question.
Posted at Wed Nov 21, 2007 5:29 pm
By mhpautos, Certified 2CarPros Master Technician
Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369Reputation: 369 (369) Give Feedback | Votes: 11
Hi there,
Do you know the engine code? That would be a help. If all the timing marks are correct, I would first do a comp check to prove compressions. Then check for spark, Injection pulse and fuel pressure. You may off dislodged a sensor wire, crank angle, cam angle and ecu has not got input signal. A ecu code read will help as well.
Mark (mhpautos)
Posted at Tue Jan 15, 2008 10:54 am
By asandberg6, New to the forum
Subarus are interference motors, if you turn a cam far enough without the belt on you will bend valves and lose compression. If you tuned the crankshaft with the belt off you could have bent quite a few valves. If you have a dual overhead cam motor you need the special tool to index the cams after removing the pulleys. If you didnt have the special tool i assure you the pulley is on wrong and your out of time regardless of what the marks say.
Neutral
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
