Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Ford Escort Vehicl...
Auto Repair1998 Dodge Dakota Heate...
Auto Repair2000 Chevy S-10 Brakeli...
Auto Repair2000 Dodge Caravan Head...
Auto Repair2000 Dodge Dakota Hit P...
Auto Repair2004 Buick Rendezvous H...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Plymouth Breeze Fuel Tank Problem
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Nov 12, 2008 2:03 pm
By JWhitcroft, Knows how to drive!
Give Feedback | Votes: 0
1997 Plymouth Breeze Two Wheel Drive Automatic
When you go to fill the gas tank, you can only pump about a dollar into it, and then the gas pump shuts off, and fuel spits out due to the back pressure created. Only way to fill this car up is if you control the pump handle and fill the car, it seems, drop by drop.
Does the fuel tank attach itself to the fill tube with a rubber hose, and could that hose be collapsed inside? Also there are two vent holes above the fill hole, do these vents attach to the fill tube before the rubber hose, that I suspect is collapsed? Or is there somthing else that could cause a blockage?
Find a car repair manual for your Plymouth Breeze Repair Question.
Posted at Wed Nov 12, 2008 3:57 pm
By Dave H, Certified 2CarPros Technician
Reputation: 98.7Reputation: 98.7Reputation: 98.7Reputation: 98.7Reputation: 98.7 (99) Give Feedback | Votes: 5
hope this helps
Removal & Installation
Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE. Disconnect negative battery cable. Disconnect fuel pump 4-pin wiring harness located under trunk mat on left side near left rear shock tower.
Locate body grommet near base of rear seat. Push grommet out and feed wiring harness through hole in body. Remove fuel cap. Raise and support vehicle on hoist. Drain fuel from tank through fuel tank drain plug, located on left edge of fuel tank.
Install fuel tank drain plug.
Disconnect fuel filler tube from fuel tank.
Disconnect rollover valve hose. Remove fuel tank mounting straps. Lower fuel tank from vehicle.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
