Electrical problem
1997 Other Mitsubishi Models 4 cyl Two Wheel Drive Automatic 56000 miles
My Mirage would die on me whenever I stopped. I took out the alternator and it was bad (7.4V). I also replaced the Battery because it had tested bad as well. Now when I drive my battery light and hand brake light flicker on and off. It does not stay lite but as I drive they light up and then go out if I accelerate more or touch the brake.
Find a
repair manual for your Other Mitsubishi Models.
Posted at Fri May 09, 2008 3:06 pm
By
Advertisment,
Find a
these lights coming on together indicate problem in alternator voltage regulator. double check the wiring to the alternator and make sure you didnt leave a plug loose or the feed wire a little loose, also check the tension on the belt. is there a loud squeel when running from the belt area?
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
