1997 Other Kia Models Knocking noise when accelerating
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
1997 Other Kia Models 4 cyl Front Wheel Drive Manual 95,000 miles
Over the last couple of weeks my 1997 Kia Sephia LS has started to make a noise....when I accelerate there is a sputtering/ knocking noise and it seems to be getting louder. The noise seems to be coming from the front of the car (I'm not exactly sure which side). It only makes the noise when I'm in gear and pushing the gas. If I'm in neutral and rev the engine there's no noise. I'm just wondering what the problem might be?
Problem could be detonation/spark knock-Have the ignition timing and knock sensor checked out-might not be retarding the timing or wrong type of fuel being use. Or an EGR problem
I would say your problem could be apart of the Exhaust system. Either Blown Exhaust gasket (cheap easy fix) , hole in the Exhaust Manifold (Could be shop welded at local auto parts store) or somewhere else down the pipe. (Minor-to-major repair needed. Exhaust patch kits dont last, so dont bother)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
