Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1999 Buick Regal Stallin...
Auto Repair1995 Other Oldsmobile Mod...
Auto Repair2001 Hyundai Elantra His...
Auto Repair1997 Dodge Caravan Brake...
Auto Repair2002 Saturn Vue Intermit...
Auto Repair1997 Honda Accord Car Wo...
Auto Repair1996 Dodge Caravan 96 Ca...
Auto Repair1989 Ford Mustang Engine...
Auto Repair2000 Other Oldsmobile Mod...
Auto Repair1995 Honda Odyssey Car W...
Auto Repair1994 Buick Regal Ignitio...
Auto Repair1992 Honda Accord Engine...
Auto Repair1994 Ford F250 Blinkers
Auto Repair1999 Ford Contour Fan On...
Auto Repair1998 Chevy Silverado Cha...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Other GMC Models Transmission hard shift after engine g
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Wed Mar 05, 2008 11:41 am
By Hiness, Have Donated
Give Feedback | Votes: 0
Transmission problem
1997 Other GMC Models V8 Four Wheel Drive Automatic 160,00 miles
My Suburban has run great until I started commuting. I've had a trouble keeping Antifreeze in the overflow 9so I'm sure the engine is getting extra warm but not overheating) When the engine gets warm after driving on the highway and I get off the highway, the first time I accelerate it gives a rough shift from 1st to second. (this continues on in the city) I've been checking the transmission fluid regularly and it is getting low. We had someone SUPPOSEDLY change the cooling lines and check it but he obviously didn't do what was needed. I really don't want to damage the vehicle by not doing what it needs. Any suggestions??
Find a repair manual for your Other GMC Models.
By Advertisment,
Posted at Wed Mar 05, 2008 1:36 pm
By mastertechtim, Tech level 9
Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5 (246) Give Feedback | Votes: 16
the problem with losing coolant is most likely from the lower intake manifold gaskets(if they have not been updated yet) the transmission problem sounds like a stuck shift solenoid, there should be a code for this stored in the vehicles computer.**this will not illuminate the check engine light but will be stored. autozone will scan the truck for free, get back to us with the codes.
Posted at Wed Mar 05, 2008 4:37 pm
By 2CarPro Jack, Certified ASE Technician
Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6Reputation: 603.6 (604) Give Feedback | Votes: 78
Bunch of valve body updates for that trans as well, relating to harsh 1-2 shift
Posted at Thu Mar 06, 2008 10:13 am
Hi Master Tech Tim,
I took the Suburban to the Auto Zone and they pulled the code - P1870-
Transmission is in 4th gear with TCC engaged and the ECM has detected excessive slippage whn comparing the input shaft speed with the output shaft speed.
I checked the fluid level last night and I'm wondering if I've got it full enough. It's really hard to see the hash marks on the dipstick. It appears that the "Hot engine Level" is almost 2-3 inches up from the bent part of the dipstick. Does that sound correct? Maybe I've kept the level WAY too low.
If it is the solenoid you mentioned, is this something my husband can do?
Thanks so much for the help!
Posted at Thu Mar 06, 2008 11:20 am
i looked up the 1870 and there are several updates that a transmission shop can do to the valve body of transmission. my advice is to bring it to trans shop. they will not need to rebuild it, just update the valve body. very common on these transmissions.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
