Car Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1997 Other Chevrolet Models Hard to start vortec 305 cheyenn
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Sat Jul 26, 2008 10:08 am |
By
DAVID12,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
1997 Other Chevrolet Models V8 Two Wheel Drive Automatic 131800 miles
I have a 1997 c1500. It is having trouble starting in the morning the past year. I have replaced , plugs ,wires , rotor, cap, ignition coil, battery to optima, upgraded and replaced all ground straps and wires to larger cleaned all contact points to grounds and put dielectric grease on it. I have replaced fuel filter several times fuel pump 2 times, just replaced coolant temp sensor, also tps sensor, starter and ignition switch. There is no code that is what makes it hard!!!!!!!!! AFTER driving to work it seems to be just fine afterwards no starting issue like in the morning. Can somebody help me please?????????????
| Find a
car repair manual for your Other Chevrolet Models. |
Posted at Tue Jul 29, 2008 7:49 am |
By
klshiel,
Tech level 3 |
(8) Give Feedback | Votes: 0 |
Have you cleaned the intake?
| Find a
Posted at Tue Jul 29, 2008 4:23 pm |
By
DAVID12,
New to the forum |
I actually have cleaned it about a month ago the throttle body from butterfly up is shiny, I even took out the iac sensor and cleaned it the other day, just to doit. I have also replaced crankshaft sensor also when it was not starting at all , but cranking.
I was doing a test the other day unhooked the fuel pump it would crank beautful of course not start , hooked the pump back up and it was difficult to crank.
Thanks,
D.T
Iwill clean the throttle body agian nothing wrong with trying!!!!!
| Find a
Posted at Wed Jul 30, 2008 5:49 am |
By
klshiel,
Tech level 3 |
So when your getting fuel it cranks slower? Well the only things I can think of that fit that is the timing is way off, which would make it run horribly. Or it may actually be flooding. I don't know if your truck has the flooded start like the GM's around that year, but you pump and then hold the throttle wide open in run before cranking it and it doesn't send as much fuel to the intake.
| Find a
Posted at Wed Jul 30, 2008 5:58 am |
By
klshiel,
Tech level 3 |
Also, I don't know how you clean the intake but something I like to do is with the engine running spray a small amount right into the throttle body short spray at a time. To much at once will stall the motor but it wount hurt anything. You will set a code with the air cleaner and what not off, and it will make a large smelly cloud, but it will get the valves cleaned up. If the first few times you do it the smoke cloud out your exhaust is black that is all carbon that was built up. keep going till the vapor is grey.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
