Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1997 Oldsmobile Bravada 6 cyl Four Wheel Drive Automatic 152000 miles
My car has the Select Trac. We had our first major snowfall of the season and I realize that I don't have 4 wheel drive when I need it. Do I have a transmission problem?
Find a car repair manual for your Oldsmobile Bravada Repair Question.
Not transmission but possibly transfer case related. You would need to test the system to discover where the problem is. It is possible that the problem is related to the ABS system or to a problem with the front drive section in the transfer case.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
