Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Jaguar Xj6 Blowing...
Auto Repair2004 Buick Rendezvous H...
Auto Repair2005 Chevy Cavalier Fue...
Auto Repair1995 Honda Odyssey Stal...
Auto Repair2000 Chevy Cavalier Los...
Auto Repair2005 Other Honda Models ...
Auto Repair1996 Chevy Tahoe Underc...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Oldsmobile Bravada ERROR CODES PERSIST
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Oct 27, 2008 2:24 pm
By proofed, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1997 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic 102000 miles
qUESTION IS DUE TO MY OWN STUPIDITY OF ADDING YR OLD GAS FROM BOAT. WOULDN'T START, FINALLY BURNT OUT ALL BAD GAS, STILL BARELY RUNS, REPLACED 4 O2 SENSORS, CAT, MUFFLER TAILPIPE, PERFORMANCE THE SAME. HAD PRO CLEANED EMISSION SYSTEM DONE MISFIRE CODES OF PO300 ALONG WITH 137 AND 143. NO IMPROVEMENT, NO POWER, #3 CYLINDER IS MISFIRING LIKE CRAZY, COMP TEST OK, FUEL PRESSURE AT 40 + CAT GOT SO HOT MELTED CASING AROUND GAS TANK (THE REASON FOR REPLACING) CHECKED FOR VACUUM, NEW GAS FILTER, PCV. EITHER PLUGGED INJ OR SOME OTHER COMPONENT LIKE MAP (CLEANED) SHORT, PGR VALVE, IAC COULD BE CAUSING BUT AS CAR IS WORTH AT MOST 3 GRAND, I HESITATE TO PUT 1200 IN A FUEL INJECTOR HARNESS AND BOOKS SAY DO NOT REPLACE JUST THE OFFENDING ONE. IDLE ROUGH, NO POWER, TAKES FOREVER TO GET TO 50 MPH, SERV LT INTERMITTENTLY BLINKS BUT ONLY GOES AWAY IF i DISCONNECT BATT OR PULL FUSE. CURRENTLY RUNNING BEST FUEL PREM. WITH THE CLEANER SHOP PUT IN OIL AND GAS. i AM GOING BROKE IN CLEANERS, BOUGHT A MULTITESTER TO SEE IF i COULD ISOLATE SOME EMISSION COMPONENT AT FAULT, BUT HAVEN'T GOT TO IT YET. RAN BEAUTIFULLY BEFORE BOAT GAS FUBAR, BUT WAS STUCK IN THE WATER W/O POWER TO RETRIEVE IT OUT. i NEVER WOULD HAVE USED THAT GAS BUT AT 4 BUCKS A GAL IT WAS 120 BUCKS WORTH. SO FAR I AM APPROACHING 1000. IN REPAIR. I WRITE THIS SO OTHERS DO NOT OUT OF DESPARATION BURN THEIR FURNACE OIL IN HOPES OF GETTING TO WORK. :.) THXS IN ADVANCE, ME? I AM LOOKING FOR A 50-60S SMALL V-8 TRUCK THAT I CAN STILL WORK ON. "ANOTHER REASON TO HATE OPEC AND FOSSIL FUEL CARS" "LEARNT MY LESSON LEE"
BTW IT HAS A V-6 4.3 LITER SYSTEM AND AS NEAR AS I CAN FIGURE A CMFI INJECTION SYSTEM
DEFINED BY THE W IN VIN WHICH CALLS IT CPI. WHICH I THOUGHT MEANT COMPICATED PUNISHMENT FOR IDIOTS. BUT REALLY MEAN COMPICATED MONEY PIT FOR IDIOTS. GIVE ME A CARB AND SOME GUMOUT SO I DON;T HAVE TO LEAVE MY SENSES AND STAY IN, WHEN MY MATE SAYS OUT.
Find a car repair manual for your Oldsmobile Bravada Repair Question.
Posted at Fri Dec 12, 2008 7:45 pm
By SWilliams, Loves to help!
Reputation: 58.2Reputation: 58.2Reputation: 58.2 (58) Give Feedback | Votes: 3
40 psi fuel pressure isn't good. You should have closer to 50.
As for the CPI, the reason you cannot change just one injector is because you only have one. It feeds different cylinders through poppet nozzles.
However if you're only seeing a miss on number three and your SURE it isn't plug related you can clean the poppet nozzles. You just pull the CPI unit and soak the poppet nozzles in cleaner, then shoot some cleaner through them.
It is also possible that the fuel pressure regulator has failed. That could be dumping extra fuel into the engine causing the hot cat and muffler. You can follow the test procedure in the book and see what you get.
The regulator in attached to the back of the injector inside the intake.
Also you can buy a re-man spider unit from
http://www.lindertech.com/reconinj.htm
or
http://www.robstark.com/scpi.htm
for about 300 bucks.
You need to get a factory book and follow the testing/troubleshooting steps. The online ones at mitchell are pretty good and they are not that expensive either (compared to a factory set from Helm that will run almost 200 dollars)
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
