1997 Oldsmobile Bravada engine misfires in morning and some
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1997 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic 418000 miles
The fuel pump is working and i have spark at the ignition coil. Two days ago wouldn't start but was trying to. Showed 1/4 tank of gas so I added about 3 gals and it findly started but was missing when reeved up. It would start up every time after that. Two days later after sitting at the body shop it want start even though it shows 1/2 tank. It has been missing in the morning for about a year, but after I would kill it a coupel of times it runs great all day. I had put it in the shop a year ago for this problem and they put a new fuel pump and a fuel pressure regulator and an intake gasket. Ran ok for a day or 2 and the the same problem. It has failed to start once until this time, but started later that afternoon. I ran some bearmans b12 in it before this last tank of gas.
Find a car repair manual for your Oldsmobile Bravada Repair Question.
Posted at Fri Nov 07, 2008 8:39 am
By
Jacobandnickolas,Certified 2CarPros Master Technician
Hi:
This sounds more electrical than it does fuel related. Have you ever had it scanned for trouble codes? If not, I recommend you do that. Most nationally recognized parts stores will do it for free. Off the top of my head, it could be a crank sensor, but I can't be sure. See what they find when it's scanned.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
