Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1997 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic 137000 miles
The car recently started over heating and burning up anti freeze. I changed the thermostat and had the water pump changed. It is still over heating to the point that the fluid in the over flow tank is bubbling hot.
HELP
Find a car repair manual for your Mitsubishi Eclipse Repair Question.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
