Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2005 Volvo V40 Heater P...
Auto Repair1967 Ford Mustang Pleas...
Auto Repair1993 Chevy Silverado Ha...
Auto Repair1979 Chevy Malibu Fuel ...
Auto Repair1998 Land Rover Defender...
Auto Repair1999 Mercury Sable Plea...
Auto Repair1993 Subaru Legacy Timing
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Mitsubishi Eclipse Starting Problem
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Nov 04, 2008 3:58 pm
By Whiteboy5555, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1997 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual 111000 miles
When I go to Start my car up in the morning, it startes fine. Everything Runs Great! Then after I shut it down and go to start it up again when it is warm. It will turn over but wont start, then if i shut the ignition off and try to start it again sometimes it will start and some times it wont and I have to repeat the process or let it cool down and then it usually starts. The Check Engine Light Came On When This Occured.
Thanks Kc
Find a car repair manual for your Mitsubishi Eclipse Repair Question.
Posted at Wed Nov 05, 2008 4:23 pm
By rasmataz, Certified 2CarPros Master Technician
(13) Give Feedback | Votes: 78
Check the fuel pressure confirm that its within specifications and comeback with the readings . Or you can try below and determine if its a fuel or spark issue when it refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Posted at Fri Nov 07, 2008 1:38 pm
Error Code p0352 It says that my coil is going bad... Replaced Coil Still same problem somtimes it starts somtimes it dosnt. I also got some electrical cleaner and cleaned the connector on the coil and the two connectors on the Computer it self..
Posted at Fri Nov 07, 2008 1:43 pm
Get the computer scanned for OBD2 code/s Autozone will do it for free and get back. Also have you checked the fuel pressure? Also test the ASD relay if it has one-
Posted at Mon Nov 10, 2008 11:46 am
Well I hunted down the ASD Relay and pulled the plug out and it was all gunked up, took some electrical cleaner and spryed it on it. Hasnt repeated the problem yet. I read somewhere that the engine light will go out after 40 or so successful starts is that true?
Posted at Mon Nov 10, 2008 12:10 pm
I read somewhere that the engine light will go out after 40 or so successful starts is that true? Yes the computer is relearning itself-40 key starts or more-
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
