Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
1997 Mercury Tracer 4 cyl Two Wheel Drive Automatic 100000 miles
I have a rattle in the motor. I believe it is coming from the cam. when you press on the gas it rattles really bad. something sounds like its about to jump out of the engine. what could be the problem and how can it be fixed?
have your heat shields checked that is on your exhust. If it is really bad any shop should tell what is wrong with before you let them work on it and most of them will not charge you just to look at it.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
