Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Ford Windstar No Heat
Auto Repair2000 Toyota Corolla Tra...
Auto Repair1991 Isuzu Amigo Won't ...
Auto Repair2004 Mini Cooper Very B...
Auto Repair1998 Ford Explorer Comp...
Auto Repair1996 Ford Taurus Rear D...
Auto Repair1999 Ford Taurus
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Mazda Protege Help pls..
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Dec 01, 2008 6:39 pm
By lanzyboi, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
1997 Mazda Protege 4 cyl Front Wheel Drive Manual 300xxx miles
I have a problem with my 1997 mazda protege.Last summer i was driving in the highway and when i stopped in the gasoline station i smelled something. and when i moved my car an old lady told me that there's a lot coolant under my car. so i checked and i saw my coolant resrvoir. it was full and i don't remember putting that much coolant on it. so what i did is i took some water from the washroom and put it on my radiator.i also drained the reservoir to the right amount it suppose to have.so when i went on to where im suppose to go i checked it again.and i saw the coolant coming out from my reservoir. so i put another one.i asked my friend who knows a bit about cars.he said its not bad cause the oil and water is not mixing. So after a week i used it to go for a long drive (3 hours drive) i brought a lot of bottled tap water with me in case i might need them and i did. So i still reached my destination. We rented a cottage there and stayed there for 2 1/2 days so i didnt use it for 2 1/2 days. but when we're going back home after 2 hours of driving on the highway i just noticed my temperature is going up to the edge so i stopped and pulled my car on the side. and the engine is smoking. my friend who knows a bit about cars was with that time he helped to cool down the engine. we took the inside road. and the temperature will rise again. so i just figured how to drive.i have to switch the gear immediately. so i was able to reach home. then i was still able to use it for a week but driving it like that way(switching gears immediately) i brought to some mechanics.and they diagnosed it first.He also drained and flushed my radiator. he said some parts of my radiator is cold and some are not while running. it went well for a while.so i thought its ok now.and i was able to drive up to my place without shifting immediately and not overheating.but when i reached my house i saw the coolant coming out from my reservoir again.He told me to buy this powder (prestone) that seals leaks in your cooling system. but it didnt work. so i went to another mechanic. he said its only the thermostat. so he replaced it and after that its still the same. so he said it might be there's crack on my head cylinder or my head cylinder gasket is blowned. and they said its gonna cost me like 900 bucks so i said no thanks. i began to think maybe that's why the powder(prestone) didnt work.but still there's still few left powders inside the engine. and still didnt work. so i dont how am i gonna fix my car now?can you help me guys?its been in my garage for 5 months now. i jsut want to fix it and sell it.i already bought a new car.i was thinking it might be the water pump or the head cylinder gasket. because a year ago when i bought that car. there was a leak on the water pump. i replaced the water pump. the water pump that i bought has different holes for the screw so what my mechanic friend did is he improvised by drilling some holes on it so it will fit on my engine. and it did.so im thinking that it must be that. and i was also hearing sound like there's something loose somewhere there.i was thinking it might be the water pump when the idle is high. we just ignored because it's not making any problem at all. and i was still able to use it for year. and im also thinking that it might be the head cylinder gasket because my mechanic friend who replaced the water pump told me that i might need to replace the gasket after a few months because he already opened my engine so oil might leak out there or it might create air pockets..i dont know what's really the problem please help me..i tried opening it.its just hard especially its a DOHC engine.
Find a car repair manual for your Mazda Protege Repair Question.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
