Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Transmission problem
1997 Mazda 626 6 cyl Two Wheel Drive Manual 150000 miles
My car will not go into gear. When I push the Clutch in it push in fine, but when I try to put it into to gear i met resistence. A few times I could make it through the resistence and after that it shifted fine the rest of the day.
Well I woke up this morning to try to make it to work it and it wouldent go into to gear.
Do you think if I put fluid into my clutch master cylinder it may temporarily solve the problem? Or do I need to replace the clutch?
check the clutch operation and make sure the fluid is full, if very low, you will have to check for a leak at the master and slave Cly. Also have the transmission oil checked for correct level as well.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
