Computer problem
1997 Lincoln Mark VIII V8 Two Wheel Drive Automatic 99999 miles
I have installed a 97 double overhead 4.6 engine in a 1956 ford conv. I used the original eng. and computer harness along with the dash cluster, automatic trans. wires. I eliminated the rear oxygen sensers since I did not install cats. The car runs fine, shifts well and responds great. The 97 cluster gages worked fine,except the speedometer. I found out I needed the abs modual. I did cure that problem by using a cluster out of a 93 Mark. speedometer and gages work. My problem to get the eng light to go out I know I would have to eliminate other items in computer that is not needed. Is there a way I can get this done. Dealers can't help me or recommend anyone to flash the computers.
