Welcome to our question and answer forum were over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Suspension problem
1997 Lincoln Mark VIII V8 Two Wheel Drive Automatic 96000 miles
In the AM when I go to use the car the front end is down. I turn on the motor wait a few minutes and the front end rises and I get a message to check the air ride system. I have no other problems the rest of the dayl
I brought the car to the dealer and he said he could fix it for $2000. I left, any other alternatives that I could afford which isn't very muck
Find a
repair manual for your Lincoln Mark VIII Repair Question.
Posted at Wed Mar 12, 2008 11:04 am
By
Advertisment,
Find a
Posted at Wed Mar 12, 2008 11:42 am
By
merlin2021,Certified 2CarPros Master Technician
It would have been helpful to know what the trouble code is! You can try here for cheaper parts and advice than the Dealer will be...
http://www.americanairsuspension.com/
Find a
your codes or problem areas can only be... control module, by the glove box, the front air solenoids at the top of the air bags, the compressor dryer inside front passenger wheel well, compressor relay on the bracket for the compressor.... all of these can be bought cheap at a wrecking yard and replaced by you.
Find a
Posted at Thu Jul 17, 2008 11:41 pm
By
Not correct! Junk yard parts for air suspension is hit or miss, some of these lincolns are there BECAUSE of the suspension. Also you missed the air lines, they are also a big problem where the run through the car and frame, they rub, and get holes...
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
