Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1997 Lincoln Continental Car will not start sometimes
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Fri May 23, 2008 5:03 am |
By
jon_h26,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1997 Lincoln Continental V8 Front Wheel Drive Automatic 180,00 miles
I also have a 97 Lincoln Contental that wont start sometimes. It sat in a parking lot for 3 days and would not start, then they towed it and it started when it got to the shop. They replaced the fuel pump and filter. 2 weeks later it would not start again and when it was towed to the shop it started again. Getting an electrical diagram will not help if you dont know what to look for and replacing items is a hit and miss deal. Any mechanics have the same problem found out what is really wrong and what to fix?
| Find a
car repair manual for your Lincoln Continental Repair Question. |
Posted at Fri May 23, 2008 10:19 am |
By
jon_h26,
New to the forum |
Yes, it cranks but wont catch. When it happened for the garage the were able to place a computer on it and found the only thing wrong was low fuel pressure. Thats when they replaced the fuel pump and filter.
| Find a
Posted at Mon Jul 07, 2008 5:11 am |
By
hannjo,
Likes cars! |
The car repair shop finally isolated the problem to the crank case sensor. They originally replaced the fuel pump and filter but it did it again after 3 days. After the crank case sensor was replaced it has not happened again.
| Find a
Posted at Tue Sep 09, 2008 6:35 am |
By
mtcontinental,
New to the forum |
| blackop555 wrote: | glad to hear you have found out your problem.
wouldnt have guessed that caused low fuel pressure. |
97 Lincoln will not start but cranks good. I have had it towed to the shop and each time after being towed it starts. The fuel pump, crank shaft sensor, fuel relay and spark plugs have all be replaced. Car has 86,000 miles. I am getting ready to have it towed again - any advice?
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
