Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Honda Accord Hmmmm...
Auto Repair1998 Land Rover Defender...
Auto Repair1995 Honda Accord 1995 ...
Auto Repair1999 Saturn Sl2 Start Up
Auto Repair2000 Hyundai Tiburon Sp...
Auto Repair1994 Honda Accord Coola...
Auto Repair1994 Oldsmobile Cutlass ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Jeep Wrangler Hesitation
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Wed Dec 03, 2008 2:47 pm
By stevenwerth, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1997 Jeep Wrangler 4 cyl Four Wheel Drive Manual 125000 miles
IN my 97 Wrangler 2.5l Manual Trans, When I start to drive (EVERY time) I get about a 1/4 mile and it hesitates, hot or cold. If I keep accelerating it just stalls (doesn't kill the engine). Once I let off the accelerator and clutch and them pump the accelerator it kicks back in and doesn't do it again until I turn off the car and then drive it again.
I have Changed both O2 sensors, new manifold, new plugs and wires, and replaced the MAP sensor.
Any suggestions on what this might be?
Thanks
Find a car repair manual for your Jeep Wrangler Repair Question.
Posted at Wed Dec 03, 2008 7:23 pm
By James R. Weizel, Moderator
Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3 (138) Give Feedback | Votes: 8
Do you have, or have you had, A check engine light recently? I would be suspicious of the throttle position sensor, but a little more information will help narrow it down. Please advise.
Posted at Thu Dec 04, 2008 7:56 am
The check engine light will come on periodically and stay on a couple days and then go off for about a week, then repeats.
Posted at Thu Dec 04, 2008 9:24 am
What ever is tripping your check engine light could be a valuable clue to your problem. Auto Zone, and most moast other parts stores will scan your computer for free. If you will have this done and let me know comes up, we can go from there. Please advise.
Posted at Thu Dec 04, 2008 10:11 am
Actually, I bought one online that I think is going to help. It should be here today. I will wait for the check engine light to come on and then let you know what the code is. I have to say, this is a GREAT resource for help. Thanks for this service.
Posted at Thu Dec 04, 2008 3:15 pm
All the moderators here enjoy sharing experience, not only with the posters, but with each other. What ever tripped your check engine light will be stored in the computer's memory. You can scan the memory any time, even if the CEL is not on.
Posted at Thu Dec 04, 2008 3:38 pm
I used the ignition ON-OFF ON-OFF ON mode and it gave me the following codes:
22: Engine coolant temperature sensor above or below acceptable voltage.
12: Direct battery input to PCM was disconnected within the last 50 Key-on cycles.
14: MAP sensor input above or below acceptable voltage. 5 volt output to MAP sensor open.
Interestingly enough I put a new MAP sensor in the other day and my diagnostic OBD machine said it was at 5 volts
When I hooked up the OBD machine I just got today, it gave me trouble codes:
P0118 (M)
Engine Coolant Temperature Circuit High Input
Engine coolant temperature sensor input above the maximum acceptable voltage.
P0108 (M)
Manifold Absolute Pressure/Barometric Pressure Circuit High Input
MAP sensor input above maximum acceptable voltage.
Posted at Thu Dec 04, 2008 4:21 pm
I would go ahead and change the temp sensor, clear all the codes and see what comes up in the next day or two. The CTS input will have a bearing on map sensor processing. Let me know.
Posted at Thu Dec 04, 2008 4:23 pm
Where is the Temp Sensor?
I just took it for a drive with the ScanGuage installed.
The coolant temp leveled out at 195 degrees and the MAP was 5 PSI at Idle and maxed out around 13.5- 14 PSI at full accelleration. I read that up to 15 PSI is normal. I am not sure if this helps......
Thanks
Posted at Thu Dec 04, 2008 4:51 pm
Check to see what the temp sensor reads when you start it up cold.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
