Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Honda Accord 1995 ...
Auto Repair2000 Hyundai Tiburon Sp...
Auto Repair1999 Saturn Sl2 Start Up
Auto Repair1994 Honda Accord Coola...
Auto Repair1994 Oldsmobile Cutlass ...
Auto Repair2000 Honda Accord Check...
Auto Repair2001 Honda Accord Headl...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Jeep Wrangler heater blower
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2, 3  Next
Posted at Mon Nov 17, 2008 10:06 am
By bmichele, Have Donated
(10) Give Feedback | Votes: 0
Heater problem
1997 Jeep Wrangler 6 cyl Four Wheel Drive Automatic
My heater blower motor went in the spring. I didnt fix it or use it until a few weeks ago, when I finally fixed it. Now I don't have the blow power that I used to have! At first it wasn't working at all. Then we did something to one of the vac lines and it works a little bit now. ie: when it is on high it blows like it is on low. We don't know where to look. Is there something wrong with the vac line? or is there another line that we are missing?
Please help! it get very cold here!
thank you,
michele
Find a car repair manual for your Jeep Wrangler Repair Question.
Posted at Mon Nov 17, 2008 2:17 pm
By racefan966, Moderator
Reputation: 118.2Reputation: 118.2Reputation: 118.2Reputation: 118.2Reputation: 118.2Reputation: 118.2 (118) Give Feedback | Votes: 4
Now do you have 3 speeds or just one? If you only have one speed then the blower motor resistor might be your problem. Get back to me and we will go from there.
Posted at Tue Nov 18, 2008 6:03 am
I have 3 speeds, low med & high. Before the blower motor went in the spring it was working great. It would heat the whole jeep in 10 min in really cold weather. Now when its on high it sounds like low and there is very little blowing out, almost like something is blocking it. In fact, thats what we thought the problem was (it wasnt blowing at all at first) until we found the vac, and it started working to where it is now.
Posted at Tue Nov 18, 2008 10:05 pm
Ok so do all three speeds work now or is there only one speed now? There is no cabin air filter on this so that won't be a problem. Did you park the Jeep for a long period of time by chance? There isn't a chance that a critter built a nest in the heater box? Just checking I run into in more often then you think. Just trying to cover anything. Get back to me and we will go from there.
Posted at Wed Nov 19, 2008 4:44 am
I don't think they all blow, and there is so little heat blown out when its on high-that is where I leave it.
I drove the jeep all summer long, I just never used the blower. When the old blower motor was in there I used it until it wouldnt work anymore, then summer was here so I didn't use it all summer. So of course as it started getting colder and I needed heat I had to replace it. So there is no chance that something built a nest in there.
Posted at Wed Nov 19, 2008 9:19 am
Ok great I would like you to pull the blower motor resister and see if it looks ok. See the resistor sets the speeds and when the old motor was pushed to its max use it may have demanded to much voltage therefore the resistor did its job and blew on or more coils leaving you with one speed. Here is what yours looks like. It should be bolted to the heater box close to the blower motor. You can check for resistance with an ohm meter to see if there is continuity.
Posted at Thu Nov 20, 2008 5:20 am
but we replaced the blower motor. my husband said that the resistor is in that.
Posted at Thu Nov 20, 2008 8:36 am
Sorry no it is not it is in the heater box. It will be near the blower motor but it is not part of it. Look for the part that looks like the pic that I sent you and check it. Let me know what you find.
Posted at Thu Nov 20, 2008 9:44 am
ok, we are going out right now to look it over.
also, my jeep has a/c that hasnt been used in years
Posted at Thu Nov 20, 2008 11:17 am
so far this is what i have -
there is 3 settings - low, med & high. You can hear and feel the speed change when u turn the switch setting from lowto high. it just doesnt blow like it used to. and when u turn on the recirculate it blows louder, but it doesnt really come out anywhere that it should be - u cant feel it in the vents...
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
