Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Ford Ranger Check ...
Auto Repair1998 Jeep Wrangler Heat...
Auto Repair1996 Geo Prizm Get Noth...
Auto Repair1996 Honda Civic Engine...
Auto Repair2002 Mercury Mountaineer...
Auto Repair2003 Honda Civic Air Ba...
Auto Repair1997 Isuzu Bighorn Door...
Auto Repair More Repair Topics...
Car Repair Talk - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 Honda Civic Turn signal problem: details below
Posted at Sun Jun 28, 2009 11:26 am
By lom109, Likes to hang around!
Give Feedback | Votes: 0
1997 Honda Civic
will not turn on during signaling and the corresponding rear signal light (and light in the dashboard) flash fast!
However, will turn on when lights are manually turned on (for night driving).
I initially thought it was burnt-out, but it blinked during keyless entry and turned on completely during the night time driving mode.
Find a car repair manual for your Honda Civic Repair Question.
Posted at Sun Jun 28, 2009 11:36 am
By KHLow2008, Certified 2CarPros Technician
Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200Reputation: 3200 (3200) Give Feedback | Votes: 48
Hi lom109,
Check the ground wire connections for the light that is not blinking. Any bad ground would cause the light not to work correctly.
Posted at Mon Jun 29, 2009 5:41 pm
Thanks for the prompt and quick reply,
Follow up:
1. Both filaments in the bulb are intact (no tinkling when shaking it)
2. there is only one black wire coming from it, it cannot be a grounding problem (unless the wire disconnected downstream)
I say downstream, since the light turned on for a while, before I whipped the car in a certain direction (fast turning), and the light messed up once again.
I have found out there are 2 wires, one for low light, other for blinking (brighter)
The low light works, but the brighter one seems to be the problem, any ideas how a 3496 bulb works? (there are only 2 connections, power/ground it seems, but it has TWO filaments?)
Posted at Tue Jun 30, 2009 1:10 pm
If you are refering to the turn siganl lights, they should have only 1 filament. 2 filament means the bulb is wrong, it is for the brake and taillights.
Remove the bulb and see if the socket has 1 or 2 terminals in it. Single terminal will have 2 wires while double terminals willl have 3 wires altogether.
Posted at Sat Jul 04, 2009 11:24 am
My car i think is different than what you think... its a civic,
the front signal lights have 2 filaments with 2 terminals sticking out.
I guess I'll send this to my automechanic, but before I do, I was wondering whether this problem can lead to one of my rear brake lights on the same side not working as well.
(again, all bulbs are fine, no tinkling), so I have a huge hunch its a wiring problem.
All i did was take out the headlight assembly... store the bulbs... and put reassembled the headlight... plugged the lights back in...
and something doesn't work.. how the hell does this happen Sad
Posted at Sat Jul 04, 2009 6:05 pm
Sorry if I had misunderstood your previous post.
The front bulb is a plug in type with double filament. Problems are usually caused at the seats where the bulb plugs in. Remove the bulb and recheck the bulb wire hooks at base of it. When it has gone out of position, installing it would cause improper contact and sudden movement can cause it to lose contact.
There should be 3 wires for the socket, Black = ground, Red/Black = side lamp and Green/White is for the turn signal.
When one signal bulb fails, other bulbs on the same (side) circuit would blink very fast.
Posted at Thu Jul 09, 2009 2:55 pm
thanks a ton SmileSmile
it was a combination THANKS Smile
Posted at Fri Jul 10, 2009 5:47 am
You are welcomed and glad that problem had been resolved.
Have a great weekend.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
