Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Honda Accord 1995 ...
Auto Repair2000 Hyundai Tiburon Sp...
Auto Repair1999 Saturn Sl2 Start Up
Auto Repair1994 Honda Accord Coola...
Auto Repair1994 Oldsmobile Cutlass ...
Auto Repair2000 Honda Accord Check...
Auto Repair2001 Honda Accord Headl...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Honda Civic Blowing AC Condensor Fan Fuse
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Sep 05, 2008 6:42 pm
By ozzyflash, Likes cars!
Give Feedback | Votes: 0
Air Conditioning problem
1997 Honda Civic 4 cyl Front Wheel Drive Automatic 140000 miles
The AC Condensor Fan Fuse continually blows. If I replace the fuse while the engine is cooled down the AC will run and cool the car for 5 minutes or so while at idle. Once the engine warms up the fuse blows causing the condensor fan to quit and compressor clutch to disengage. If I replace the fuse while the car is at running temp the fuse will blow immediately upon hitting the AC power button. It does not appear to be a wire shorting out to ground as the fuse only blows when the car is at running temp... the AC will run with a fresh fuse and cold engine. Is it possible for the compressor clutch or condensor fan to short across the coils at higher temperatures to create an increased current draw? Is there something that I'm over looking completely?
Find a car repair manual for your Honda Civic Repair Question.
Posted at Mon Sep 08, 2008 7:50 am
By KHLow2008, Moderator
Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7 (142) Give Feedback | Votes: 14
Hi ozzyflash,
Either the fan motor or clutch coil is shorting, disconnect either one to test which is the cause.
Posted at Mon Sep 08, 2008 5:59 pm
So that others may benefit from this thread. I disconnected the ground ( black wire atop the compressor) from the compressor clutch and idled the car with the AC switch ON. The fuse did not blow and thus singled out the coil in the AC Compressor clutch as the source of the problem. There is also a connection near the condensor fan that can be disconnected to test out the fan.
Additionally, the coil can not be purchased on its own. A Condensor clutch kit can be purchased for about $99 (found mine at advance auto parts). It is possible to swap out the clutch while the condensor is on the car, but it will require pulling 3 of the mounting bolts out and pivoting the condensor on the 4th bolt so that it can be angled downwards to pull the pulley off (frame rail is in the way otherwise). The benefit of doing it on the car is that the freon does not have to be evacuated and refilled. Thanks for the help here.
Posted at Sun Sep 21, 2008 4:44 pm
In the previous post I mentioned that the compressor clutch coil could be replaced on the car. That is correct... I misused the term condensor for compressor. The coil can be replaced with the compressor on the car if 3 of the 4 bolts are removed and the compressor is allowed to pivot (pulley side down) . This allows room to pull the pulley off the shaft and expose the coil. Without doing this the frame rail prevents the removal of the pulley/coil.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
