Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1997 Honda Accord 4 cyl Automatic 64000 miles
my car all of a sudden stop the engine going 70 mph i tried to pull over and then it started up again by itself, then stopped again and repeated the same thing till i got home.. 100 miles the S.R.S. light came on i never lost headlights but turn signal didnt work 3 people said its the fuel relay now i just changed the fuel filter 1 mth ago any idea before i occure a major bill to diagnos this????
Yes, fuel pump relay could cause this problem. With out whether it is fuel or spark or both that are failing we are just guessing. A pump relay is not that expensive as parts go.
it may be the pump itself, but I would start with the relay. Also, you may want to have your computer scanned to see what triggered the SRS light. This may hold a valuable clue. Hope this helps.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
