1997 Honda Accord why won't my car shift into gear
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
You need to get a scan done to find out what is causing the CEL to show. As to the gears not shifting, check if transmission fluid is level is correct.
If fluid level is correct, you migh have a failing trans that needs a rebuild or replacement or the TCM might be faulty.
Get the CEL checked first, it might be related to the trans not working.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
