Transmission problem
1997 Honda Accord 4 cyl Two Wheel Drive Automatic 156000 miles
Recently changed CV Joints. When I first get in car in the morning and put the car in reverse I here a fairly loud clunk when the transmission engages. this only happens in reverse. This does not happen once the car is driven, Nor does it happen when I put the car in Drive, just reverse.
It use to do this in Drive only and not reverse. However when I recently changed the CV Joints I rotated the tires by hand to check clearance issues with brake lines and it changed from happen in forward to happening in reverse only.
Any ideas?
Thanks
