Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 GMC Sierra MISFIRE
Posted at Mon Nov 02, 2009 10:37 pm |
By
huneke89,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1997 GMC Sierra V8 Four Wheel Drive Automatic 11000 miles
I have a 97 sierra with 110k miles, i keep getting a engine check light on and always says cylinder #2 misfire, i hAVE RECENTLY replace spark plugs, wires, dist. cap/rotor and ignition coil, but the problem persists, i only feel any sluggishness once in a while but can't figure out the problem, maybe a fuel injector? i Dont know but running out of ideas and money.. if you have any ideas or thoughts i would greatly appreciate it.. |
Find a
car repair manual for your GMC Sierra Repair Question.
Posted at Tue Nov 03, 2009 6:23 pm |
By
obxautomedic,
Certified 2CarPros Technician |
        (913) Give Feedback | Votes: 31 |
Check for Vacuum Leaks
Check Fuel Pressure and Fuel Pressure Regulator
Check engine compression
Check the Air Intake Tube for band tightness, cracks, etc.
Check Injector will need a noid light to test.
Other possibilities are....
Weak Crank and/or Cam Sensor
Faulty Engine Mount
IAC (Idle Air Control) Motor
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
