Free Car Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 Ford Windstar dash removal
Posted at Tue Nov 03, 2009 8:36 am |
By
yrichard,
Have Donated |
Give Feedback | Votes: 0 |
Heater problem
1997 Ford Windstar 6 cyl Front Wheel Drive Automatic
I've had a local machanic help me find the problem, broken blend door. He says that i need to remaove the dash to get to it. Do you have any diagrams that would help? I will donate ten dollars at this time and will be glad to donate more if you can help me. Thank you |
Find a
car repair manual for your Ford Windstar Repair Question.
Posted at Wed Nov 04, 2009 7:57 am |
By
racefan966,
Certified 2CarPros Technician |
     (2963) Give Feedback | Votes: 44 |
Ok first off there is no need to remove the entire dash unit. The blend door and blend door actuator is located behind the glove box. So you need to remove the glove box door and the glove box to gain access to the blend door. Then you remove the blend door actuator and the blend door is under that. Here is a pic of what you are looking for.
Find a
Posted at Fri Nov 13, 2009 2:11 pm |
By
yrichard,
Have Donated |
last message was helpful, but now I've found that I need to remove the blend door, it's broken. What is the best way to do that? |
Find a
Posted at Sat Nov 14, 2009 6:49 am |
By
racefan966,
Once the blend door actuator is removed the blend door should be underneith it from what it say's. |
Find a
Posted at Sun Nov 15, 2009 12:04 am |
By
yrichard,
Have Donated |
Yes that is true, I can see where the actuator enters the blend door. My question is how do I get to the blend door, has the only thing you can see out side of the heater box is where the actuator attaches to the door. Will I have to remove the entire heater? |
Find a
Posted at Tue Nov 17, 2009 8:01 am |
By
racefan966,
From what it say's you should only have to remove the blend door actuator and then the actuator mounting plate and the blend door is under that and remove the door and install new one. It don't say anything about removing the entire heater. See pic below.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
