Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Chrysler Concorde ...
Auto Repair1997 Hyundai Accent Ozy...
Auto Repair1989 Ford F350 How Do Y...
Auto Repair1999 Oldsmobile Alero
Auto Repair1993 Chevy Cavalier Hea...
Auto Repair1994 Mazda Mx3 Wont Start
Auto Repair1996 Ford Taurus Heater...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Ford Thunderbird Fuel Pump
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Aug 30, 2008 3:57 pm
By jaledesma, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1997 Ford Thunderbird V8 Two Wheel Drive Automatic 142000 miles
How do you replace the fuel pump in a 1997 TBird?
Find a car repair manual for your Ford Thunderbird Repair Question.
Posted at Sun Aug 31, 2008 10:42 am
By RyanBlizz, Likes cars!
You have to drop the fuel tank. It is actually not as awful as it sounds, but try and get it as close to empty as possible (syphon the gas out if your fuel pump is already dead). I say this because I changed one that was almost full and nearly drowned. Wink
1. Put the car on jack stands - I just did the back, but I should have put the front up too, it would have been much easier.
2. Take the middle section of the exhaust off, I think it is four nuts on the front, then you can slide the tail pipe section off the rubber cushion mounts.
3. Put a standard floor jack under the fuel tank (especially if it still has gas in it) and then unbolt the fuel tank. There is a metal "strap" running from side to side with a bolt on each end. I think there is also two bolts near the rear axle.
4. Oce all the bolts have been removed you can lower the tank a couple of inches, BUT don't let the tank hang from the filler tube in the back. There is two small rubber hoses and the filler hose (larger rubber) attached to the rear of the tank with hose clamps. Take them loose and then drop the tank down.
5. It should be completely loose from the car except the fuel pump wiring and fuel lines that run near the unibody under the passenger door.
6. Disconnect the fuel pump. I cannot remember if there was a special fuel flange here or not... If there is they are tool is fairly inexpensive ($10), just go to your local auto parts store and tell them you need a Ford fuel quick disconnect tool. Anyway, disconnect the fuel lines - mark which side is which, (I think the hoses are different sizes for the supply and return, but just in case), unplug the electrical connection and then pull the tank all the way out from under the car.
7. I used a large flat head screw driver - as a tap - and a rubber mallet to unscrew the fuel pump, it unscrews counter-clockwise, and it is 1/4 - 1/2 turn to completely pull it out. Mine was stuck in there fairly good, just be careful not to break any plastic tabs on the fuel tank.
8. Once the fuel pump is removed, reinstall the new one (follow above steps in reverse) - make sure you put in the new gasket that comes with it. - Before you install, it would be good idea to test it, I installed a bad one from Autozone and had to redo the whole installation the next day. - You can test it by plugging it in to the wiring (before tank installation) and turning your key to run. You should hear the pump motor start and run for about 3 seconds. Also you can move the float up and down to test your fuel sender unit. It should make your dash guage move up and down.
9. Reinstall tank, pretty much the opposite of above, just make sure you get the filler tube lined up before you put the bolts in place.
10. Reinstall the exhaust, WD-40 works wonders on getting that rubber cushion to slide off and on BTW.
Hope that helps... Good luck!
Ryan
Posted at Thu Sep 04, 2008 6:13 pm
Okay, I just dropped the tank again to remove the u-joints, and I would like to correct a few errors from my earlier post.
Step 2 correction: There is a cross beam that connects under the exhaust pipe. Remove this by taking out the 4 bolts (8mm heads). The exhaust has already "Y" to the single here, just remove the two nuts that connect the flange. I did not remove the entire rear exhaust, I left the rear two hangers on, and just removed the hanger in the middle.
Step 3 correction: The strap runs front to back on the fuel tank. There is 4 bolts total, one in each corner.
Step 6 correction: There are no special quick realase fuel connections here, just the standard hose clamps.
That is all that I found wrong.
Ryan
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
