Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1997 Ford Taurus 6 cyl Two Wheel Drive Automatic 202000 miles
I need to replace the starter.
I am a limited home mechanic.
But with some coaching, I know I can do it.
Where is the starter on the 1997 Taurus XL?
Is it a matter of a few bolts and plug?
Disconnect the negative battery cable and set aside
jack and support the car
locate starter and disconnect wires
remove nut over ground cable
remove two mounting bolts
good luck
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
