Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2003 Toyota Camry Serpe...
Auto Repair2000 Ford Contour Alter...
Auto Repair1998 Mazda Mx5
Auto Repair1991 Ford Festiva Dippe...
Auto Repair1995 Nissan Truck How T...
Auto Repair2000 Dodge Caravan Stee...
Auto Repair1999 Other Saturn Models...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Ford Taurus Bad evap valve already replaced
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sun Jul 06, 2008 7:21 pm
By Ianto, Have Donated
Give Feedback | Votes: 0
Computer problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic 85000 miles
Hi, thanks for a really great website.
I had a computer diagnosis of a "bad evap valve" from a mechanic I trust 3 months ago after the check engine light had been on. The valve was checked, found defective and replaced.
The check engine light stayed off for a good 500 miles, but then came back on again. The mechanic I had originally taken the car to is far away and difficult, though possible, to get to, so I took it locally. I got the same computer diagnosis, sadly, of a bad evap valve.
I didn't have the repair done yet and called the original mechanic who said they would look at it again without charge.
Taking the car to the original mechanic though requires 2 days off work, one to drop the car off and one to pick it up, so I'm still thinking.
I've owned this used car for about 5 years with very few problems, and none major.
I did have a diagnostic done a couple years ago by a mechanic I trust less that he said showed a bad 02 sensor in front, so I replaced only the 2 upstream sensors. That code doesn't show anymore but I wonder if that could still relate to the current code and I should replace the downstream 02 sensors as well (I know I should replace all 4 at once but it was too pricey)
I haven't ever had a tuneup on the car though I was told several years ago the spark plugs were fine and should last to 100,000. However, reading the tips and forums here, it sounds like a tuneup is a good idea. Could that actually be the root of the problem?
Or something else could cause the bad evap valve code?
Edit: Just looked up the code from the recent repair and it is as follows. I don't have the code from the original repair and I see there are a number of codes regarding evap valve, so maybe this one is different?
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
A brief 2nd question, my turn signal indicators will flash unevenly, sometimes very quickly at first (double speed) for a few seconds, and then at normal speed. Any thoughts on that? I did have a new a battery and remanufactured alternator installed prior to experiencing this problem. Also a new serpentine belt.
I'm no mechanic so I'm looking for the best way to get the evap code issue fixed permanently.
1) Just replace it again locally and hope for the best?
2) Take it back to the difficult to get to place and have them look at it again?
3) Thoughts about what else could cause the code?
Find diagnostic tools, replacement parts or locate a car repair manual for your Ford Taurus Repair Question.
By Advertisment,
Posted at Sun Jul 06, 2008 11:29 pm
By Dr. Hagerty, Moderator
Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5Reputation: 367.5 (367) Give Feedback | Votes: 8
There are several fault relating to evaporative emissions and they dont all indicate the same thing. If the valve set a fault and a code and now is back on for the same code then go back and let the original mechanic recheck his work, if it is for some other issue with the evap system then further diagnostics are in order. The replacement of the post-cat sensors should be performed if there is a reason to do so, I am not a fan of changing them for no good reason. The flasher issue could be due to a bulb of the wrong wattage or one that requires replacement, inspect them and see what you find.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
