Electrical problem
1997 Ford F350 V8 Four Wheel Drive Automatic 148000 miles
I have a 1997 F-350 with the E40D transmission and just got done changing the tranny filter. After topping off the fluid I went to start the vehicle to run through the gears before rechecking the fluid but now the truck won't start. Why?
Find a
repair manual for your Ford F350 Repair Question.
Posted at Fri May 09, 2008 5:30 pm
By
Advertisment,
Find a
it acts like the batteries dead but i put a tester on both and the both are putting out 12.6 volts. the weird thing is that all the lights are still bright until just after the glow plugs cycle, then they dim just a bit but the multimeter still reads good power.
Find a
do you get a click from the starter? check with a test light to see if you have power at the starter motor. ****make sure when you did the trans service that you did not accidentially knock off the wires on the transmission neutral safety switch. also try moving shifter into neutral to start or also try wiggling shifter and see if that has any affect
Find a
I appreciate the help, tried it in neutral and part and wouldn't do anything but after the slight roll when i took my foot off the brake when going from neutral to park changed her mind and got her going. thanks again.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
