Car Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1997 Ford F150 vibration
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Wed Aug 06, 2008 5:03 pm |
By
aeolianrane,
Have Donated |
Give Feedback | Votes: 0 |
Shakes or Wobbles problem
1997 Ford F150 V8 Four Wheel Drive Automatic 143000 miles
I have a vibration in the rearend I think. When I opened the dif to change the fluid I noticed the spider gears were tore up in the limited slip carrier. I found a open rear for the truck with the same gears and installed it. I had the vibration before I changed rears. The clutches also spun in the carrier. The rear that I installed had a little movement in the pinnion flange, I tightened it up just enough to stop the movement. Would the spider gears and spun clutches in the carrier make that vibration? Also when the trans shifts(4r70w)either down to 1st or up to 5th there is a pretty good vibration and clunck. All other gears seem to shift perfectly. Thanks for your help, good luck.
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your Ford F150 Repair Question. |
Posted at Thu Aug 07, 2008 7:31 am |
By
aeolianrane,
Have Donated |
sorry, automatic, should have said 4th. U-joints good already checked them. No check engine light. Idles great so I did not suspect converter. I don't completely understand converter lock-up operation. educate me in simple terms.
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Thu Aug 07, 2008 9:55 am |
By
aeolianrane,
Have Donated |
I have a new of spider gears and I have a set of new clutches form ford racing. When I get all installed in carrier and rear end back in truck I will let you know what happens. Hope it will fix all problems. Thanks for all help!
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
