The temp fix worked beautifully. I can now operate the vehicle, but the brake lights do not work. So what should I check next?
| blackop555 wrote: |
this is a temp fix usually, most fords if you turn the key to the first click after the car is on you can shift it to neutral and start it.
Is your brake lights illuminating when the brake pedal is pressed?
try shifting from park and pushing brake pedal at the same time.
get back to me. |
