Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic 130000 miles
I changed the rotors, brake calipers and brakes pads. When I started to bleed the brake lines I started from left to right and bleed them numerous times and got nothing but brake fluid everytime so i did the same with the rear from left to right and bleed the master cylinder nothing but fluid came out. Is there something that I am not doing or need to do different? Thanks.
I'm just going to throw this out there, I have seen this once or twice, make sure the bleeders are on top! If you hang the calipers on the wrong side, the bleeders will be at the bottom, and air will NEVER be bled out! Bleed sequence is RR, LR, RF, LF.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
